You had the bubblers on at the same time?
Brian what do you mean by tees? Is that the white part attached to the fitting in the picture below? Or are the tees inside the pvc pipe after I take the return and housing out?
The t's are behind the plaster they are part of the plumbing/fittings
This is a t:
Ah ok. So then those must be inside the pvc. If so, I couldn't reach them by hand from outside the spa. I'll have to jump in later and take a closer look.
You probably won't be able to see them or remove them. I think he wanted you to remove the parts that are in the holes. Like the jet/fitting you had pictured earlier. Take all of those out so it just looks like your return pipes and run the spa - it will force everything out that is sitting in the pipes just waiting to clog your jets.
They are all out and it doesn't solve the problem.
[emoji1304] hopefully Brian wakes up and has another solution
That's not how they work. With that fitting removed, is there any evidence of plaster in the lines?
A couple of small pieces came out when the returns were removed. Also I've taken some pieces out of the pump basket. Also there have been some pieces kicking around in the pump basket that I can't get ahold of (they get into the pvc when I turn the pump off to open it).
Are you sure the airline isn't blocked?
Don't know. How would I know?
Are you certain the pool/spa return valve is completely rotated to the spa position?
Yes
Plasterers often use sponges to plug the main drain and spa suction lines. Any chance the line is plugged?
I don't believe so. There was nothing visible when the jets were removed.
What do the jets look like in Spillway mode (pull from pool, return to spa jets)?
Don't know. I'll check. I've only run the spillover pulling from the pool and returning to the spa drain.
Brian,
ur new color looks good. i know everyones monitors are diff along with white balance of the picture taken but i can see the diff in the plaster. you deff know there is black mixed in there and deff has more of a grey vs white look to it.
i think it looks great. looked good before. i didn't realize you had an issue with the grout on ur build until now reading back after you helped on my thread. i appreciate the help.
i too wanted to have a grey based plaster to get a deeper blue but my wife wanted it a bit brighter. another builder mentioned that he mixes 1 bag of french grey to 9 bags of super blue, but it isn't an official color so i didn't want to there with my builder and plaster crew. i might have revisit it after going back over ur plaster redo.
what was the issue with ur returns. i got part of it but missed part of it too. what did you have and what do you have now? i thought a return is a return?
NOW that is some TFP water there! The Jewel look going on!
Kim
