Re: South Florida Pool & Outdoor Living - STARTUP PHASE
Its easy. From left to right where they come through the ground:
Acid Pump
Waterfall Return
Waterfall suction
Air Line
Conduit for IC and actuators
Spa Return
Spa Suction
Vacuum Line
Main drain
Pool Return
The two lines at the bottom of the picture are skimmers
A waste line is plumbed before the filter
The two lines behind the waste valve are for solar heat
5 Actuators!
I'm pretty sure it would be much easier for me to become the "one in the middle" rather than trying to understand your plumbing set up. :bowdown:
Acid Pump
Waterfall Return
Waterfall suction
Air Line
Spa Return
Spa Suction
Vacuum Line
Main drain
Pool Return
5 Actuators!
