South Florida Pool & Outdoor Living - STARTUP PHASE
kimkats
47,408
Tallahassee, FL
I like the idea of the water line tile. It will throw quite a bit of color into the pool.
See if you can get your hands on some cheap tiles from Lowes or such that are the color of your spa tiles. Find a way to up up about 5 of them temporarily to see if you like it and go from there.
Kim (no cheering on this one)
BigEinAZ
592
Mesa, Az
FWIW, I think your tiles and plaster compliment each other nicely, but that's cold comfort I'm sure. Hope you work something out that you can live with . . .
JoyfulNoise
Platinum Supporter
May 23, 2015
17,458
Pentair Intellichlor IC-40
Does the pool not have waterline tile in it?
Not to throw cold water on the re-tile/add-tile idea, but I really don't think you want to do that. They'd have to chip-out the plaster to get the tiles in there or remove any current tiles and then replaster those areas they chipped out. It will create an ugly mismatch no matter how careful they are with the chip-out and replaster.
Either the plaster has to be redone or you have to accept what is there. Anything else is going to leave noticeable marks...
grumpiebk
901
FL
Matt, the owner of the plaster company said the same thing this morning. Yes we do have waterline tile, it just matches the decking. So it seems it is replaster or keep it as is. But doesn't a replaster come with the same issues - won't they need to chip around my step/shelf/bench marker tile also to reapply new plaster? Will it look "refinished"? It's a new pool so I certainly don't want it to look anything but.
JoyfulNoise
Platinum Supporter
May 23, 2015
17,458
A complete replaster will look like new. As long as they do a good job being careful around the tiles, it should be fine. You could even have them knock off the step/ledge marker tiles that got grouted with the dark grout and redo that with the plaster as grout. But the waterline tiles will be fine.
MannyCPA
55
Tampa
Brian, just had the pleasure of reading this thread for the past hour. Fantastic stuff thank you for sharing. I live in Tampa, FL and am currently going through the motions of quoting and spec'ing out a pool. We have a small 10*14 foot covered patio that is woefully under sized for our outdoor space needs; and unfortunately all the PB want to throw up a composite roof which we have no interest in. Looking to tear it down and build a brand new covered patio extending the entire read of our home. Was hoping you could share a little more on your covered patio demo, rebuild, specs, etc. Who you used and cost would be helpful too (if you don't want to share publicly I'll happily take a PM) :D
grumpiebk
901
FL
Manny, I sent you a PM with specs. Our original builder grade covered patio was similar to yours - 8x16. Literally only big enough for a grill and a couple of chairs, all of which got wet when it rained. It's like a living room out there now!
bdavis466
Platinum Supporter
Aug 4, 2014
5,529
San Clemente, CA
Oh come on! Where better to shoot a flame thrower in your flip flops than south Florida???
I'd love to but even I would have trouble covering up a couple week old plaster job.
I know you aren't happy with the color but give it some time. Most pools don't look anything like they originally did after a few years. If you want more teal then let a little bit of algae take hold... Problem solved, for free!
JoyfulNoise
Platinum Supporter
May 23, 2015
17,458
Or a couple of gallons of root killer - Copper Sulfate usage???
(Sadly, the OP in that thread removed a lot of the original images showing the copper stains all over his plaster....his name was Brian too, weird?!?!)
bdavis466
Platinum Supporter
Aug 4, 2014
5,529
San Clemente, CA
I didn't even think of copper staining. That's even better!
I went and looked at a water feature at a shopping center today that had 3 - 2hp pumps with inline chlorinators on each pump all for maybe 1000 gallons. The plaster was flaking off, delaminated, heavily copper stained and scale 1/2" thick at the waterline.
The guy said he's going to paint it :roll:
Brian, remember no matter what happens, there's always paint!
JoyfulNoise
Platinum Supporter
May 23, 2015
17,458
{TFP Overlords now regretting "Expert" badge designation and reviewing By-Laws to see how easily it can be revoked....}
kimkats
47,408
Tallahassee, FL
Matt, Matt, Matt..............what are we going to do with you??? Oh wait I know!!! Send out the Matt signal!! See I have found brain work tires someone out more than anything else so I will just keep your brain busy with "not following directions" folks! LOL
Brian, Did you offer to blast it for him??? LOL
Grumpie Ask Matt to share his pic of what his plaster used to look like and what it looks like now. That will show you how it "ages". See if you think you can live with it knowing it will change after a while.
Kim:kim:
grumpiebk
901
FL
You guys are having fun at my expense! But I can hack it. I just feel bad for all of the other readers like Manny who have to sort through 25 pages.
We have a beautiful pool and when we actually jump in it will all be worth it. It's only that the color, plumbing, automation, bubblers, and chemistry are all off..... [emoji14]
kimkats
47,408
Tallahassee, FL
Grumpie you have some of the best help out there in your "house" so tell us what you want to work on first!
I can do the chemistry if you like!
Kim:kim:
grumpiebk
901
FL
Kim:kim:
I was just playing. I really do have the A team along for the ride with our build and appreciate every ounce of help. Once we get through this plaster issue, it will be COMPLETE!
JoyfulNoise
Platinum Supporter
May 23, 2015
17,458
Kim was referring to this -
This is what a plaster patch looks likes (new versus 4 year old plaster) -
