South Florida Pool & Outdoor Living - STARTUP PHASE
And then from the ball valves I was able to dial them into the desired play height:
Since the bubblers are on ball valves, I unfortunately can't set those through automation, but that's ok. It's an easy manual adjustment once or twice a week on the weekend. One thing I did notice was that there was not an actuator on our pool/spa valve. Shouldn't there be since I have automation? Why would my bubblers (on/off, not height adjustment) have an actuator but not my spa spillover? I suppose it's an easy fix for the PB, but C'mon! Really?
Thanks Kevin! I actually played around with the bubblers a bit today. When turning off the spa spillover we definitely get old faithful!One more thing for the bubblers, have your guy come out with you and tweak settings. I rather suspect it is going to be a combination of valve flow and pump speed changes to get exactly what you want. I would suggest you set two settings in your easy touch for your preferred bubblers: (1) old faithful geyser and (2) gentle kids playing.
