Would you mind explaining how you do your CYA test? This seems to be the trickiest test for everyone and I just want to make sure you are doing it properly...
Plan for tonight-
Check-
FC
CC
CYA
TA
Also test what ever water source you use to refill the pool. Do a full blown test and write the info down for future reference. Will make it easier to predict you levels when you add water.
My guess is-
FC 12ish
CC 1-1.5
CYA 30-40 hopefully
TA 140-150
So.. based on my guess,
add bleach to get FC back up to 16 for over night...
Elevated CC's mean the chlorine is doing what its supposed to... The sun will help burn off the excess and the filter will take the rest.
CYA will have to come up at some point being you have an SWG...
CYA/Chlorine You can do this now or wait.. If you do it now, it will increase the target FC slam level and you will have to add quite a bit more bleach after you add stabilizer -OR- you can press on at the 30-40 target level until your pool clears up, then raise the CYA to SWG operating levels... Personally, I would shut off the SWG and rely on the bleach for the time being. The SWG is helping maintain the elevated chlorine level but as you can see it cant quite keep up (12 down to 9.5 in 6 hours). They aren't designed to slam pools so they struggle when this process is going on. You can continue to run it to assist over night and when you are at work and cant be there to add when more chlorine is needed.
TA comes down every time you add MA to adjust PH... and will go back up when you add water to the pool depending on what your fill water alkalinity level. No need to worry about this but should be in the back of your mind. We can play with this after the slam is over.
How much free time do you have to commit to this? I did mine on a weekend when I was available to check levels every 1-2 hours...
