Page 14 of 76 FirstFirst ... 4111213141516172464 ... LastLast
Results 261 to 280 of 1512
Thread: Doheny's Discovery, S200, Active20, Triton owners club
  1. Back To Top    #261
    Mod Squad pooldv's Avatar
    Join Date
    Aug 2012
    Location
    DFW, TX
    Posts
    24,976
    Re: Doheny's Discovery, S200, Active20, Triton owners club
    I could detangle the cord between every use. And I need to detangle it after a week. There are pics in post 218 of this thread of my tangled up cord.
    TFP Moderator
    If TFP helped you or saved you money - Become a TFP Supporter! <--Click here
    2012 build and pics, 20k gal gunite, black onyx pebblesheen, OK flagstone, IntellifoVS, cart filter w/Pleatco, IC40 SWG, Solartouch, 5 12'x4' solar panels, HP50HA heat pump, 8mil solar cover, borates, TF-100 test kit, SONOS, Doheny's Discovery Robot, hot tub on bleach
  2. Back To Top    #262
    needsajet's Avatar
    Join Date
    Jan 2016
    Location
    Sydney, NSW, Australia
    Posts
    4,537
    Quote Originally Posted by YippeeSkippy View Post
    Needsajet- its not too late. My manual calls for the cord to be laid out straight in the sun occasionally.
    Yip
    Thanks! I'll give it a go
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
  3. Back To Top    #263
    Join Date
    Mar 2015
    Location
    Orlando, FL
    Posts
    33
    I am biting the bullet and going with the Discovery. I figure the extra year of warranty is worth the $200 price difference over the Saturn, and any better job is does cleaning the water line is a bonus.
    16,000 gallons, in-ground, plaster, Hayward Pro Grid DE filter, 2 HP single-speed pump, solar heater, solar cover, Doheny's Discovery (Maytronics S200) robot, K-2006 test kit.
  4. Back To Top    #264
    Killer95Stang's Avatar
    Join Date
    Aug 2012
    Location
    Sunny SoCal
    Posts
    749
    Quote Originally Posted by needsajet View Post
    I'm helping on a pool with a Maytronics robot, and wondering about the cord tangling. It needs untangling every time. I noticed in the manual that you're supposed to lay the cord out in the sun for a few hours with no "twist" tension before using the robot in the pool. The owner didn't lay it out straight in the sun before using the robot, so I'm wondering if that would have helped?
    As far as the promised precise pattern, it seems to me that the circulation in the pool pushes the robot off it's long straight runs, and/or causes it to run a curved path if the cord gets pushed by the water movement. I checked and it's not stealing any airline bottles of Crown from my test kit. It does a good job either way, but leaves me curious.
    I'm getting about 3 to 4 cycles of my cleaner, before I decide to unplug and straighten the cord. As far as pattern goes.. I've stared it for a long time and It seems like it always drives past every large leaf in the pool. Then I get tired of watching and I come back later and all the leaves are gone. I guess my robot has performance anxiety...
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
  5. Back To Top    #265
    mas985's Avatar
    Join Date
    May 2007
    Location
    Pleasanton, CA
    Posts
    12,042
    If you find that you are always unwinding the cord in the same direction, you can pre-wind the cord in the same direction and get a few more runs out of it.
    Mark
    Hydraulics 101; Pump Ed 101; Pump/Pool Spreadsheets; Pump Run Time Study; DIY Acid Dosing; DIY Cover Roller
    18'x36' 20k plaster, MaxFlo SP2303VSP, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
  6. Back To Top    #266
    Mod Squad YippeeSkippy's Avatar
    Join Date
    Jan 2012
    Location
    'burbs of Augusta, Georgia
    Posts
    8,851
    Quote Originally Posted by Killer95Stang View Post
    This had me seriously laugh right out loud! Good one, Stang.
    Maddie :) 12K Fiberglass IG, Infinity 4000 automatic cover, SWCG, Hayward Sand Filter, Hayward 1.5 Pump, Doheny Discovery Robot, Savi Melody LED pool lights, outdoor speakers and other assorted doo-dads. Sundance Altamar Hot Tub.
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
  7. Back To Top    #267
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    4,214
    Also available in an orange/black color scheme, depending on your sports team preference, branded as a Dolphin Triton 2017 model (different from the previous Triton 2016 and prior). http://www.sunplay.com/dolphin-trito...VaGRoCi5zw_wcB
    For Comparison: http://www.doheny.com/poolsupplies/D...hin-13416.html
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  8. Back To Top    #268
    Join Date
    Aug 2012
    Location
    Sunny SoCal
    Posts
    749
    Since the "S" models are available in so many colors based on who the vendor is, I'll probably customize mine when the time comes for replacement parts. I was thinking the blue tracks would look cool from the Active 30i. We could start a whole new hobby of customized pool robots. Maybe take one into war on the Battle Bots show! Alright.... I've gone too far.
  9. Back To Top    #269
    Join Date
    Aug 2012
    Location
    DFW, TX
    Posts
    24,976
    Hey, I'm in! I want blue tracks!
    TFP Moderator
  10. Back To Top    #270
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    4,214
    So I'll be opening my pool in two weeks. I'm not reinstalling my cleaner's booster pump which was cut out in the fall. I'm expecting that the Discovery will again go on sale for $650 this year as it's another year older and it was at that price a few times last year. However, I want a robot at my command when I open. So after reviewing the Discovery twins, I am rolling the dice and getting a refurbished Dolphin/Maytronics Active 20 from Poolpartz.com for $499. It comes with a 1-year warranty serviced by Maytronics directly only. So I'm saving between $150 and $300 with a few strings attached. Shorter warranty, not local service, and the potential that a refurb. will be more troublesome than a new model. I'll update as the year progresses on my how things go for one particular refurbished specimen. I'm not sure why the Active 20 refurb. was priced better relatively speaking than the Active 30/S200/s300's refurbs. they had (I may find out soon!) Used Hayward booster pump and Hayward Kreepy Krauly Legend for sale!
  11. Back To Top    #271
    Join Date
    Aug 2012
    Location
    Sunny SoCal
    Posts
    749
    That's a great deal.... I would take the risk with a shorter warranty at that price!
  12. Back To Top    #272
    Join Date
    Jan 2015
    Location
    Tx
    Posts
    15
    Quote Originally Posted by bmoreswim View Post
    Thanks for the heads up on this. I have also been waiting for the Discovery to go on sale, but decided to jump on this instead. Ive never been one to purchase anything refurbised so Im a little nervous, hopefully it works out ok for us both!
  13. Back To Top    #273
    el duderino's Avatar
    Join Date
    Jun 2008
    Location
    Austin, TX
    Posts
    118
    would be curious to know exactly which models are the same as the Discovery. I would like to find the best color/price combo on this type of cleaner to replace my ancient Polaris 280 Black Max (Fred)
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
  14. Back To Top    #274
    Join Date
    Aug 2012
    Location
    DFW, TX
    Posts
    24,976
    Maytronics S200 and Dolphin Triton are the same as the discovery.
    There are 3 models
    S100 which has 1 brush
    S200 which has 2 brushes
    S300 which adds blue tooth and some programming options
    All others are some version of above.
    TFP Moderator
  15. Back To Top    #275
    Join Date
    Jan 2015
    Location
    Tx
    Posts
    15
    Quote Originally Posted by pooldv View Post
    There are 3 models
    The Dolphin Active 20 is the same as the s200 and discovery also.
  16. Back To Top    #276
    Join Date
    Jun 2008
    Location
    Austin, TX
    Posts
    118
    It appears that the following are also the same:
    Pentair Prowler 920
    Dolphin Cayman
    Dolphin Active 20
    Again, I'm interested in the best price/warranty/color combo of all of these. They have the features and price-point I'm looking for. Seems with the price hike (and sales tax for TX residents) the Doheny Discovery may no longer be the best pick of the bunch
  17. Back To Top    #277
    Join Date
    Jan 2015
    Location
    Tx
    Posts
    15
    From Sunplay.com:
    Dolphin Active 20 = Dolphin S200 = Dolphin Cayman = Dolphin Nautilus (2017 and Later) = Pentair Prowler 920
    The Truth About Pool Cleaners: What Your Pool Store Isn’t Telling You | Sunplay
  18. Back To Top    #278
    Join Date
    Jun 2008
    Location
    Austin, TX
    Posts
    118
    The Dolphin Nautilus seems to be consistently cheaper than the others, but interestingly has horrible reviews on Amazon??
  19. Back To Top    #279
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    4,214
    It's the Dolphin Nautilus PLUS from 2017 on that is the twin. Not the Nautilus. Nautilus (with no Plus) 2017 on is a different and cheaper model.
    Ugh, I keep mixing up the Nautilus Plus. That one is NOT the same as the S200 twins. It contains two separate debris chambers not the single basket. Otherwise all is very similar.
  20. Back To Top    #280
    dirtworm_ato's Avatar
    Join Date
    Dec 2016
    Location
    Little Rock, AR
    Posts
    40
    Aside from the obvious at the end of swim season, is there another time I might could expect these robots to go on sale? We're still in our 30 day break-in period on the plaster, but I can already tell I'm going to want to pick up one of these little helpers as soon as possible. It sounds like the Discovery is highly rated, but I'd be sick if it went on sale for $650 a few days after paying $800 for it.
    Little Rock, AR - 25,000 Gallons Free-form Gunite (2017)
    Pentaire Intelliflo 2 3hp VSP & Intelliflo Whisperflo 3/4hp pump for water features
    Mastertemp 400K heater
    Clean and Clear Plus 420 sq ft cartridge filter
    Intellichlor IC40 & Intellitouch Controls
Posting Permissions
  • You may not post replies
  • You may not edit your posts
