- Nov 12, 2017
- 11,994
- Plaster
- Pentair Intellichlor IC-40
Good luck with your wife's recovery and the new pool plans.
I’ve seen that unicorn. Very watchful. Caring.+1 on the well wishes. I shallst send the elusive rainbow farting unicorn to watch over you both.
I am SO sorry to hear about your wife. Has anyone been able to say what and why it happened? As one who learns from others I feel the need to ask this.suddenly started having severe back pain
Kim,I am SO sorry to hear about your wife. Has anyone been able to say what and why it happened? As one who learns from others I feel the need to ask this.
Good luck getting things going again. Here is hoping it only goes up now for you and your wife!
You take care of you, so you're in tip top shape to care for Mrs SetSailSoon.wondering why so long the delay.
Matt,Do you feel you received “extra scrutiny” because you were an O/B or do you feel that they would do the same regardless of building one home or 3 dozen homes?
Given the errors that so many homebuyers “discover” in their “custom” homes built by big track developers, I often wonder how much grift goes on. Seems like the builders can get away with lots of un-dotted i’s and un-crossed t’s and yet the little guy gets all the extra eyeballs on their project …
Thanks Kim, she's not where she wants to be yet but she really wants the pool even more now that swimming is way easier on her back and the hot tub will be very therapeutic.I am SO glad she is feeling better! Here is hoping she keeps going up!
The metal/ fire doors can be modified with spring hinges, but I'd be surprised if they didn't come with them. We needed a metal door to the garage and it came spring loaded.I have two sliding glass doors and two hurricane rated metal doors that connect to the pool patio area.
Thanks, I was afraid of that. The doors both have springs but no where near enough to close the latch. Hoping I can get away with simple beeping from the alarm on all the doors and windows from the security system. That's all we had at the last house. with similar issues. It was built in 2013.The metal/ fire doors can be modified with spring hinges, but I'd be surprised if they didn't come with them. We needed a metal door to the garage and it came spring loaded.
Google 'automatic sliding door closer' for those.
The 54 inch latch/lock is easy to add, but is going to leave holes in your pretty doors. If the offset from the door to the trim doesn't line up, a hotel door style chain lock would likely satisfy the code, albeit hideously.
- I need to firm up the load list for the sub panel. There's a condition that requires I show the house electrical distribution and service is adequate. I have the plans showing the load list including a future sub panel for a 60 and an 80 amp 240 vac service. I had intended to use the 60 amp. Here's what it looks like now as follows after reading a lot on here:
- two 15 amp breakers for two 2.7 hp vs pumps. @JamesW calcs provided back on post 351 were super helpful for this. I'll need about 160 gpm to get decent flow over the infinity edge. So plan is to run both when we need that visual and drop down to 1 for normal circulation. I think I'm headed toward 24 hr operation @Jimrahbe style most of the time Min speed to operate the swg.
- SWG dedicated 10 amp 110 v
- one 10 amp 110 v gas heater circuit
- one 10 amp lighting
Very helpful Alan thank you. Yes I noticed they did that for the house load list. I have a copy of that so I can create a similar spreadsheet showing VA loads the way you describe . The house has 400 amp feeder from the main Transformer near the street and two 200 amp panels inside the garage. I have a convenience Outlet located near the pool panel on the wall of the house but I could easily add one to the side of the box and power it through the sub panel if needed. Do you think the existing wall panel will be adequate or do I need to plan on adding one through the subpanel?Chris, a proper load analysis is done by using the actual VA on the data plates for all directly wired devices. You don't simply add up the circuit breaker amperage. In almost every panel the total of all CB amps installed will be greater than the panel feed capacity.
You are limited to an actual load of 80% of the feeder circuit. A 60A 240V circuit can provide 14,400 VA and you can load the panel to use 11,520 VA. This can be spread out across as many CB's as necessary.
On every device the VA are on a data plate or in the specifications. Prepare a spreadsheet showing the devices being connected to each circuit and actual VA. Again, the total of all CBs can be greater than the 60AMPS as long as actual VA are less than 80% of the feeder circuit.
Will you have any convenience outlet powered through the panel? NEC requires a convenience outlet located near the pool panel.
Also I would use 20A CBs with 12 gauge wires for the two pool pumps. Wire size is determined by the CB size and not the device.
Good points you make Dirk. The coping tile around the edge of the pool is supposed to be slip resistant. I may need to be very selective to make sure it really is. Yes this design is intended to have the pool full to the narrow drain insert around the three sides of the pool. A small amount of flow when the pool is circulating will be continuous so the coping tile should be wet all the time because I plan to run the pump 24/7 on low speed.Is that tile coping sloping into the pool? It looks amazing, but consider:
1. Will that be a slipping hazard? It looks to have a texture to it, but will it? And if so, will it be enough? Wet tile is slippery. Will a texture be enough to counter that? The coping is where people stand. Some while getting ready to enter the pool. Others to just look into it. Will their feet slip out from under them, due to the wet tile and a slight slope? That could be quite a hazard.
2. Coping and decking is supposed to slope away from the pool, for various good reasons, not into it.
3. Maybe this one won't apply in Florida, but if I had coping like that with my fill water, it would turn into quite a mess. Even now, even with perfect TFP water, I have a ring of what must be calcium at my water line, on my edge tile. Because the CH is near perfect, I suspect this ring is more from evaporation. Due to the lapping of the water, it's the area of my edge tile that is both constantly wet, and constantly exposed to warm air. That combo makes for constant evaporation right at the edge of the water, which forms that nasty, white ring. Now if water is going to be lapping up onto your tile coping, that could evaporate like crazy, leave the same white residue behind, but it won't be contained to a 1/2" ring, like mine, it'll be a white smear all over that tile coping.
Pardon if I've misinterpreted what that coping actually is...
NOT SHINY??? NO BLING???? OH THE HORRORS!! (sorry had to say that due to my love of all things BLING!) Carry onDefinitely nothing slippery or shiny!
