CTFocusST
- Jul 4, 2019
- 235
- Vinyl
- CircuPool RJ-45 Plus
Brenda,
I know the frustration you are going through I spent all of last year fighting a swamp. From your poolmath logs you are being much more diligent than I was which probably is why I was going at it so long. I've been following to see if anyone came up with a solution as to why it was taking so long to maybe shed some light what I may have been doing wrong as well. I hope it gets better for you soon.
I unfortunately don't have any definitive fixes but maybe some of my experience may help in some way. I have a very small cartridge filter and it was rising in pressure very quickly, faster than I could keep up with the cleaning. I started to switch off running with and without a filter for periods of time. I started to see some improvement but never quite finished slam prior to closing. I don't know if this was removing a spot algae was growing and allowed chlorine to catch up but it was at least pointing to I wasn't cleaning filter enough. At closing was first time I cleaned filter with dish soap and Muriatic acid per instructions. Since opening up this year it has been pretty much clear all season. I also invested in robot vacuum which always seems to pick up more fine dirt than I can see. Not sure if the the filter deep clean, partial drain, winter temperatures, or robot vacuum was the turning point for me but it's been much better this season
I'm no expert but wanted to share some of things I observed going through the same pattern as you are in case any of it helps. Hopefully some of the more experienced people here can help shed some light or see something else that could be improved
