Anything rated for schedule 40 pipe with the diameter that you are using will be fine. Between the various choices, all good, there are minor variations. The heavy duty cement tends to set up more quickly, so you have less time to get the pipe into the fitting. If you are mixing PVC with CPVC or ABS you need to use an all purpose cement. If you are working at extreme temperatures use an all weather variety. For normal everyday use, almost all of them work fine, just check the rating and be sure it is rated for schedule 40 and not just for DWV.
