LooLooPoolNoob
I swear there was a full on sentient algae that was building a temple to the birds in the pine trees
Calcium has no bearing on your water clarity at this time and your vinyl liner does not need a higher CH.
Good that the OCLT is at 1 ppm or less. Did you only do the one test? I would suggest another tonight.
If you wish, you can try using a clarifier. Not the EZ stuff you showed earlier, that is Floc.
You need to get SeaKlear Chitosan Clarifier. Follow the directions. DO NOT buy cheap clarifier at a pool store.
This is only used when it has been confirmed the organics are eradicated and your filtering system is struggling. Never use clarifier for a common cloudy pool. Chlorine is what you use for that.
If you can see the bottom of the pool, you can swim. As long as FC is at or below SLAM Level.
To get refills, go to TFTestkits.net. They have refills. You will not get the FAS-DPD refills at pool stores.
When was the last time you cleaned your filter? You should check that .. and definitely flush them clean before you follow Marty's advice. I think that will help with clearing the last particulate matter... hang in there. You are in the home stretch.
Stay at SLAM level today, at least. There are three criteria in SLAM Process for success. You are not passing the clear water. The other two are as you show. Check those tonight. You can leave your pump off overnight, but you need to run it for 30 minutes prior to taking your AM sample. Before the sun hits the pool surface.So can I let my FC level drop to normal levels? Or do I need to keep it at SLAM level (my goal has been FC = 12ppm with CYA = 30ppm) until I have confirmed organics have been eradicated? What confirms this by the way? An OCLT < 1ppm and CC < 0.5ppm?
They are. The one you linked is correct.Do you happen to know if they are the same?
You can safely swim in a pool as long as the FC is above the minimum and at or below SLAM level based on your CYA. You must also be able to see the bottom of the pool in the deep end of the pool.Is there any issue swimming in the pool if the FC = 12ppm?
New to your thread and rooting for you as well. I did not see it discussed so curious to ask - at under 10k gallons did you ever consider a drain and fill at all - or at least a 50% replacement to help speed the process along? Realize it would be throwing away 14 days of slam work to consider now but itās not a huge amount of water (I suppose everyoneās water supply situation is different.)
I am not an expert on this but maybe someone could suggest something to augment your existing filter .. filter basket sock type thing or something else maybe as it sounds like filtering is your biggest issue at this point.
Good luck and you definitely have more patience than I do!!
