Hi All,
Sorry to ask this, but I couldn't find the exact circumstance in my search of this topic and just want to be sure before I connect a toggle switch to our A.O. Smith 2 speed pool pump motor...
The slight difference between what I've read and my situation is that the 220v wiring from the panel to the pump was done a long time ago -- meaning, two hot (in this case red) leads and a white "neutral/ground" wire. Also, the toggle switch (rated for 15 amps, 240 volts) has 3 tabs but no leads on them right now.
I have included the label from the motor, and if I have figured this out correctly, I will:
Any advice will be greatly appreciated !
David
- Connect one of the hot leads to the #1 connection on the back of the motor.
- Connect the other hot lead to the middle tab on the toggle switch (where the black wire comes out in the switches that already have leads attached, call it #2 on the switch).
- Run a short piece of yellow wire from one of the end tabs on the switch (either 1 or 3) to the connector labeled #2 on the back of the motor.
- Connect the white wire from the breaker box to the #3 or #4 connector on the back of the motor and also run a short piece of white wire from the remaining end tab on the toggle switch (1 or 3) to #3 or #4 on the back of the motor
David
