Mdragger88
Most of us get our refills from TFTestkits.net. Some have purchased off of sites like Amazon, but be ware the product can be old. TFTestkits only sells fresh reagents.Since I blew through my 0871 bottle I was wondering if you all happen to know where I should reorder this.
Low pH destroys the heater. Chlorine is not an issue. The very acidic stew of Trichlor bled back into the heater core and destroyed it. If you use Trichlor in a feeder after a heater, the pump should not ever be turned off while there is Trichlor there.I was told the concentrated chlorine from my frog get system that I use to have was the main reason the corrosion killed my heat exchanger. I was too afraid of that high of chlorine for those many days would have done it again
Oh wow! Always appreciative for correct information. That’s so interesting. And I’ll have to keep an eye on the PH now that I have replaced that heat exchanger...Low pH destroys the heater. Chlorine is not an issue. The very acidic stew of Trichlor bled back into the heater core and destroyed it. If you use Trichlor in a feeder after a heater, the pump should not ever be turned off while there is Trichlor there.
