Yellow silt like deposits
cchaynes
22
Wallingford, PA
I went with a less agressivne approach.
1) vac pool to waste
2) balance ph
3) add yellow treat (Yellow Treat® | United Chemical)
4) Super chlorinate with liquid chlorine (2-2.5 gal for 20,000 gal pool)
Cleared up almost in an hour
5) backwash DE filter
6) shock again as above
Results are good, it struggled to establish a chlorine level but issued dichlor shock for a third shock on day 3 and it took.
Hope this helps anyone who is looking to address this.
Pool water was in the 60-70 degree range as I turned the eater off and it was cold.
  • Wow
Reactions: Wobblerlorri
Donldson
4,588
NW Ohio
This "less aggressive" approach is actually likely to be far more aggressive and potentially damaging long-term.
I suggest anybody seeking information on a similar issue who happens upon this post to please start your own post asking for assistance. Following the advice posted by OP is not a very good way to deal with the problem. It is unlikely to be a lasting fix but will cause some potentially long-lasting problems that will only be correctable by water exchange.
cchaynes
22
Wallingford, PA
Interesting, can you elaborate on what/why this approach will not work? Yellow Treat has a long track record with mostly positive reviews.
JamesW
21,092
You convert the pool to bromine and the CYA is no longer effective, which means that the chlorine added will quickly get lost to converting bromide into bromine and the bromine will be lost to sunlight.
cchaynes
22
Wallingford, PA
The pool is perfect, CYA is in check, holds a solid FC level, perhaps if someone overused this product, then what is being said here is true and I appreciate the warning, but if used in accordance with the directions, seems to do the trick. That said, a slam isn't that much more work, so it seems like a good option too, and if the issue returns, what I will do.
Donldson
4,588
NW Ohio
What exactly are you numbers and how are you testing to get them? How do you chlorinate your water?
What do you feel the sodium bromide did to your water that would cause this problem to go away?
What do you mean when you say "the pool is perfect"?
Why do you feel it is safe to use sodium bromide "in accordance with the directions" and what constitutes "overuse" to you?
How are you sure that, of all the steps you took, it was specifically the sodium bromide that fixed the issues you were having?
Finally: how do you know the issues are actually fixed and not just temporarily hidden?
cchaynes
22
Wallingford, PA
During the process I used liquid chlorine, usually, I float pucks and shock with Dichlor. Testing is with strips, they almost always agree with a test at the pool shop.
It temporarily converts to bromine which is effective at killing the algae in question, ait then goes to a zero chlorine/bromine and a heavy shock restores the chlorine residual.
It tests well and looks perfect
Because it is proven to work and the product has been sold since 1983, I used the correct amount, as I understand it, more is not more with this process.
Because I had recently done the rest of the steps with shock and a filter recharge and it didn't go away, with this product it was nearly instant.
Who is to say I guess, but all evidence so far is that the problem is gone, in addition, the pool will be closed soon so that is good enough for me!
Like anything there are always multiple approaches that can be taken, perhaps my issue was small enough for this to work, and perhaps it will be back, and if that is the case I will update this thread.
Rancho Cost-a-Lotta
1,620
Rancho Cucamonga, CA
In the event @Donldson checked out, I'm sure he was referring to the unreliability of test strips and pool store testing. Both have proven to be inaccurate and inconsistent. Best bet is to invest in a good test kit (TF-100 or Taylor K-2006c) and do your own testing.
Best wishes...
cchaynes
22
Wallingford, PA
Best wishes...
Thanks
is there a difference between these? besides price?
Rancho Cost-a-Lotta
1,620
Check out the article below. The 2006C provides more of each reagent. If I was a pool guy working on several pools, I would go with the Taylor kit. The TF-100 is the best value for a residential pool owner.
Wobblerlorri
2006C has more reagents. The TF-100 (link in my sig) is less expensive and has more of the reagents you actually use the most.
I understood @Donldson perfectly. Your pool is not in any way a TFP pool. You use pucks and the occasional bag of shock. You use test strips and test at the pool store. By inference, your CYA is likely sky-high and you probably have a greatly lowered efficacy of your chlorine as a result. No wonder you keep algae.
If you'll read ABCs of Pool Water Chemistry and browse Pool School, you'll see what the TFP method is all about and why we challenged your algae removal method. Ah well, there's always next season. I recommend doing the reading and giving our method a try next year. You've got nothing to lose and everything to gain, especially money in your pocket.
