Hello all - New user, novice pool maintainer, could use some advice in getting rid of yellow algae once and for all. I live in Las Vegas, NV. Should be noted we've had a lot of storms lately but I am vigilant about removing organic debris out of the pool. Is not a salt system and I use chlorine tabs (which I have recently learned can negatively affect CYA levels). Here are my current water readings:
FC- 3.5
CC- .5
Hardness - 375
Alkalinity - 165
pH - 8.3
The above was done using a home kit, below is the printout from Leslie's using the same sample
Thank you for any and all advice!!!
FC- 3.5
CC- .5
Hardness - 375
Alkalinity - 165
pH - 8.3
