Would you install these suction ball valves and unions?
No, I would use all diverter valves.
And the IntelliChlor cell is installed incorrectly with a downward flow.
And I would not run skimmer and main drain 50/50.
Lots of questionable stuff on YouTube.
So you'd replace the blue handle ball valves with 2-waydiverter valves or you would not use them at all?
2-way Diverters.
Do you just mean that you would do something like 25/75 or plumbed a different way?
More like 70/30 skimmer/main drain. Bias the valve towards skimmer for good skimmer performance. So it depends on plumbing setup and you should not follow some fixed setting.
Every pool is different.
Reactions: PoolStored
Gotcha, what about the unions?
Some new pumps come with pump unions (Hayward, Sta-Rite, Pentair Super Flo, Waterway are the big names). Others, like the Pentair Intelliflow do not. For those a "hi-temp" pump union should be used. If you are going to use a 2-way valve get 2-way Jandy or Pentair diverter valves. If and when they need parts, including the diverter assembly itself, they are easy to obtain and repair. The parts are interchangeable with their 3-way valves.
