Hi All,
I'm installing a new timer to support an existing single speed pump, salt water generator, and natural gas heater. I went with the P1353ME from Intermatic because of the different mode options and support for multiple circuits. The attached wiring diagram shows the approach I plan on taking (ground wires have been excluded for clarity). I'll be using AlumiConn 3-port connectors to feed power between circuits and the equipment. This timer has a fireman's switch, but Hayward says you don't need one for their heaters (not sure if this is true).
Questions for the Group:
- Is there a different approach I should take with the wiring?
- What mode is best for this setup? My guess Is mode 6 (Aux 1, Aux 2, Aux 3)
- Will separate schedules need to be set for each of the three circuits?
- Pool - Mid to late 1960s Gunite (~30,000 gallons)
- Pump - Pentair Superflo N1 (1.5 HP)
- SWG - Hayward AquaRite W3AQR15
- Heater - Hayward Universal H-Series
