Hi Everyone
Brand new here. Have 120v and trying to replace old mechanical switch with new WiFi timer switch but the wiring has me stumped. Oddly - the timer doesn’t power on and I think it is because I am confused by the existing wiring.
This is our old mechanical timer and related wiring:
So we interpreted we have two load wires (blue and red), line/power Black) and neutral (White). So we followed this wiring instruction:
And proceeded to wire the new switch:
Line in: Black in L (Live)
Black Jumper from L to Com1
Neutral (White) in N
White Jumper from N to NO1
Com1 jumper from L and to NO2
NO1 jumper from N and Load 1 (Blue Wire)
Com2 Red Wire, Load 2
NO2 has Jumper from Com1 only
I am not entirely sure which load is which but didn’t figure it mattered as long as each was switched.
I was also surprised the Black was wired into the original timer as load when it was actual hot. I am however not an electrician so may not be recognizing an alternate way to bring line/power in.
Regardless - the device is not powering on and therefor can’t switch it. Can you help identify if my wiring is wrong?
