My pump went dead. I hoped that it was a bad timer switch and replaced the Intermatic T104. Still dead. I then called a local pool guy. We decided that the huge scorpion that was across capacitor contacts might have had something to do with the failure. Pool guy replaces capacitors and rewires the T104 timer and pool works great - except my remote override switch has been disconnected. I have the switch wires suspended in space at the moment.
My pool has two “infinity” sides. Swimming laps without the pump running dumps out a lot of water eventually making it choppy. While the T104 does have a manual override, it is past a gate, down some stairs through a locked door into a bodega/pump room. Not what you want to do for a quick swim. For that reason, I have a remote manual override switch poolside. Worked great before the scorpion committed suicide in the pump motor.
Now the question. On the standard T104 timer, what two terminals do I attach the override switch?
