I removed the light and raypac heater . It was connected to a gfci and a switch actually two one for the light and one for the pump , they all were run to a intermatic t-103 . and then into the main breaker box the pump is on a double breaker and the light and plug to another single . what do i remove to just have the pump powered and a switch and gfci if needed . the timer has five wires coming from the breaker . 1 red 3 black and one white with two white wires looped behind A
