Does this make sense? I closed the pool. CYA of 70 and FC was about 22. No Polyquat.
I'm thinking that I can (should) test the water throughout the winter as long as it’s not frozen. Thinking every week or every other week. I would just pull a bit of water using the pvc pipe/straw method and testing it with my OTO kit. If the chlorine looks anywhere near the max color on the OTO test, then run the DPD test and add chlorine as necessary. Of course I have no pump so I’d just pour in the chlorine and use my brush to swish the chlorine around in the area I put it in.
Am I over thinking this? Should I just relax and let whatever happens in the winter happen and deal with it when I open the pool, or is something like this worth it to not have a green pool come spring?
