- May 3, 2014
- 58,570
- Fiberglass
- Pentair Intellichlor IC-40
The Superflo can be connected to automation with one speed using one relay. The Intelliflo VS connects to Pentair automation with a RS485 cable and lets you program any speed for the pump you want for a specific function.
Your PB will tell you that the SWCG has a flow switch that will turn it off when the pump is not running. He is right, until the flow switch fails, and the SWCG explodes. It happens. Not often, but we have threads documenting it. You need a timer for your primary safety device on the SWCG. The flow switch is the secondary safety device. You then set the timer to run the SWCG within the schedule you have set on your pump.
