In ground pool in Southern Oregon: I have in the past... kept the water level high and done nothing but use a freeze control on our circulation pump timer....to keep the water from freezing. I thought, this year, to lower the water level below the skimmer....close off the diverter valve in the skimmer and let the freeze control/timer circulate. A few years ago, using the old method, water froze in the skimmer throat and caused some cracks and subsequent leaks.
Will my new approach work ?
Thank you.......
Thank you.......
