I’m new to the math involved with all of this so I apologize for the beginner question.
I have a Pentair SD80 filter and plan 2” pvc lines with a 15000 gallon pool.
It was recommended that we get a 1.5 hp pump with this so went with a mighty mammoth 1.5 hp pump.
Now the math the filter has a max flow rate of 75GPM, with the pump is listed at 93 GPM.
I’ve read that it’s bad juju to have the pumps rate exceed the filter. Is there a way to reduce the flow rate between the two, or an I just not doing the math right. Does the head fit into this as well?
If this pump is just wrong for the filter I want to return it before I blow out the filter.
