Will a Robot run under a pool cover?
Everett_88
162
Wichita
Pentair Intellichlor IC-40
Our PB is suggesting a Polaris 380 w/ booster pump because we have an auto cover. He says the robots typically require the cover open or cord ran through the skimmer.
Anyone have experience otherwise?
I really want to use a robot.
I plan to have the plumbing installed and capped for a booster so we could always add.
I run my robot with a cover - the cord fits in the corner where the cover bar hits the coping - there is usually a small area to easily fit the cord. The bar can also close on the cord without issues - I try not to do that. My original cover for many years was always a tiny bit crooked on closing and made a bigger gap on one corner. We just had our cover replaced this last spring and it closes much better against the coping - but the cord still fits right in the corner.
I have no problems running under the cover with the cord tucked under the corner of the cover where it meets the coping. If i could only solve the problem of it getting stuck on one of the drains periodically.
