Hi everyone,
I used this site for a lot of research so now that my pool build is finally underway I wanted to share and hopefully help someone else.
We decided on the new model by Wilbar, called the Optimum. I was looking at the Radiant for a few years and it was just too expensive, their patent must have been up because this pool is identical according to my installer.
This is a 2 inch insulated panel wall that can be installed above, semi or in-ground. We are going with semi for a number of reasons.
We had a ton of rain in New Jersey so even though the hole was dug early May it's been slow getting it up and today the concrete collar was poured. Now we just need sand and liner, then back fill. After that we plan to build a small raised patio in front of the pool and a ground level patio in front of that.
I wasn't prepared for the mess this was going to make in the yard!
