ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,322 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Aug 31, 2024 Add bookmark #21 Once you create a new account then Login to Existing Account to connect your panel to the Pentair servers.
M motomom234 Member Aug 30, 2024 13 atascadero ca Aug 31, 2024 Add bookmark #22 Says failed to connect property password incorrect
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,322 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Aug 31, 2024 Add bookmark #23 Then load Pentair IntelliCenter2 app on your phone and use the account login you created. If the IntelliCenter2 app does not work try the Pentair HOME app.
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,322 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Aug 31, 2024 Add bookmark #24 motomom234 said: Says failed to connect property password incorrect Click to expand... That for Create a New Account or Login to Existing Account? Last edited: Aug 31, 2024
M motomom234 Member Aug 30, 2024 13 atascadero ca Sep 1, 2024 Add bookmark #25 Thank you so much for your help on my issue. Everything is working great!! Your help was wonderful
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,322 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Sep 1, 2024 Add bookmark #26 motomom234 said: Thank you so much for your help on my issue. Everything is working great!! Your help was wonderful Click to expand...
