Hello all,
I am installing a SWCG and just moved into this house recently so still trying to understand all the valves and equipment. I have attached some photos but I am trying to figure the purpose for this older 5 port piece. After much googling I found it is 1 1⁄2” 5-Port Top Feed T-Valve - Part # 540365 from A&A mfg. http://www.aamfg.com/pdf/aamfg_2010-2011_Product_Catalog_R1.pdf
What's confusing is my pool only has 5 return jets and a skimmer. There is also a Spa but all the piping for that makes sense. I opened up the A&A mfg 5 port thing and all that was inside was 5 acrylic balls and LOADS of algae. Clearly it was not working. I removed the balls and cleaned as best as I could and closed it all up and ran the system. From the return jets in the pool some of the algae from this...thing... came out. When I shut off the system some DE powder started to flow out of the skimmer and when reopening the 5 port thing... One of the pipes was drained of water while the others had water in them.
I get return water to the 5 jets when this device is shut off from the valve before it and when it's opened (without the balls) it returns to the same jets (since the algae came out)
Any ideas why it would be installed this way?
