Just curious: why is this the recommendation I see around here? As with everything I've read on TFP I'm sure there's a good reason, I just haven't come across it yet.
When I started my SLAM process over a month ago (which resulted in a crystal-clear pool that has stayed clear since then, thanks!) I was in a bit of a rush due to my wife being slightly impatient.
I didn't have any long socks on hand that I could have used, so I followed the instructions on the container of CYA.
The instructions on the Clorox brand CYA said to slowly pour it into the skimmer while the pump is running, which is what I did. Never had any issues. CYA bumped up from 0 to 40, easy peasy.
So what's the reasoning for using a sock in front of a return to distribute CYA?
