Did you add Yellow Out, or Yellow Trine? They are not the same thing. I think there is more than one company selling a Yellow Out product, can you find the exact bottle you used online and post a link? Before answering any of those final questions we should probaby make sure you added sodium bromide to the pool.
Yes, here is how to lower TA, Pool School - Lower Total Alkalinity
I use pure Colorado River water as our fill water. Luckily, our water is really cheap (in the desert no less). The river TA is 130 and CH is 250 with a pH of 8.2.
Acid is my life. Twice a week. I finally gave in on the CH when it hit 900 in the pool and have done a drain / refill ($15 of water and $50 of chemicals).
Good luck. Your idea of using the pool water for landscaping and adding tap water to your pool is a great way to go. Richard in the LA area does the same I believe.
Take care.
As a fellow Californian, I can sympathize. Water is crazy expensive here in San Diego, and rock hard too. If it gives you any comfort, calcium scaling does gradually disappear once you get your TA and PH levels under control. I know because we had major calcium build up on the rock beneath our spa spillway. It used to bug me to no end. I would spend hours chipping at it, dousing it with acid, scraping it, rubbing it with pumice stones ... only to have it come right back. Once we got our water chemistry right, it pretty much started disappearing by itself.
Sorry. Yes, you added about 12 ppm of sodium bromide to your pool. Most of that is still there most likely so you are essentially managing a bromine pool. When you measure 2 ppm FC you are actually reading 4.5 ppm Br. When you add 1 ppm FC worth of bleach to your pool it is being quickly converted to 2.25 ppm Br, up until you convert all of the bromide to bromine around the 12 ppm mark. So if you added 10 ppm of FC, 5.5 would be converted to 12 ppm Br and the remaining 4.5 would stay FC until it reacts with an organic, is broken down by sunlight, or some bromine is broken down to bromide and the chlorine converts it back to bromine. These are all fairly rough numbers and your bromine bank is probably less than 12 now, but not by much.Still waiting to hear from you...
