My system is a little older than new model, but I found my 1 HP pool pump flow chart for my Pentair :
Pentair Challenger Standard Efficiency Pool Pump | 346204
current pic of system:
Expressing my understanding, please chime in if I am not mostly correct:
What I'm gathering from some of these comments and my research, is that even getting a higher rated 1.65 motor on my current 1HP high flow system, it wont change the maximum flow through my 1.5 inch piping becasue my pump is rated for a 1HP pump. But, getting the new vGreen VS 1.65 pump with lower Service Factor making it more like my current 1HP up rated SF 1.25 with basically make the motors act near the same in the overall scheme of things. Having the 1.5 inch piping, it can only handle so much (same with the 1HP pump/impellar), so in the end I should still see electric savings with the new VS 1.65 running at low flow rate over the 24hr period even though I'll probably never get a true benifit from the higher HP capability.
One question I do have is: I have a [h=1]Poolvergnuegen PoolCleaner 2-Wheel Suction Side Cleaner | White & Blue | 896584000-013[/h]https://www.poolsupplyunlimited.com/poolvergnuegen-896584000-013-suction-side-cleaner/81071p1
I noticed with my current 1HP system, I DO NOT get enough suction when I have my return lines in the open position. I have to adjust my valves on my skimmers, so that, I turn off my Main drain, and close 80% of my 2nd skimmer, so that all suction power is for the poolcleaner as it is hooked up to my skimmer 1. Only by doing this do I have enough suction for the pool cleaner to work properly/fast enough per its instruction manual. (ie: 8-11 RPMs for its wheels which indicate proper suction power is attained).
By switching to the new Vgreen 1.65, will I be able to see any difference when using my pool cleaner? or will it basically stay the same since my current 1.5 inch PVC pipe and 1HP pump/impellar are just that, the same. will I be able to not have to turn my valves for my pool cleaner to work since there is a slightly higher HP pump on it when installed?
