You can deselect FREEZE protect on the POOL and SPA modes. That's what I did. I then created a slow speed run (~1100 RPM) on one of my open AUX circuits (AUX 7) and called it SLOW. I then enabled FREEZE protect just on that AUX circuit and so it only runs the main pump at slow speed when the weather turns cold. No cycling the SPA/POOL valves. By using an AUX circuit, you avoid the heater and SWG from activating. A heater should never be run when the air temps are that cold.
I don't like the cycling at all because it can cause the SPA to drain incrementally with each cycle.
