- Mar 5, 2020
- 62
- Plaster
- CircuPool RJ-45 Plus
I installed a Century VGreen 270 variable speed pump motor earlier this year in my Hayward Super II pump housing. Lately I've noticed that the pump never seems to achieve full prime. There is always a bubble that fills at least the dome of the lid, as can be seen in this video. What is causing this? My suspicion is that there might be leaves stuck in a skimmer line, but I don't know how to test that theory. I have watched this video a hundred times, but I don't find it convincing. (I just watched this video and it says the same thing.) I have played with the valves on the suction side, turning on and off the two skimmers and main drain, back and forth, different combinations, for ten minutes, and it never finished priming (though I did pull some leaves into the basket, which bolstered my theory). I don't understand how putting a bladder in the line at city water pressure will do more to unclog it than running the pump at max speed.
The default priming speed is 2600. I have cranked it up to 3200, and the pump has still not finished priming.
A related question that I may re-ask in another thread if I can't get an answer in this thread using this thread's title: I don't know what is a "safe" pressure for my filter, a Hayward Pro-Grid 60 sqft DE. The pressure spans a VERY wide range, from 7 PSI to 35 PSI depending on the pump speed. How can I determine what the "right" operating pressure is? I've read "backwash the filter, turn the pump on, and that's the baseline pressure". Does that mean backwash AND _refill the filter with DE_? Does that mean turn the pump on _to its maximum speed_? If I take a baseline pressure reading at top speed, but never run the pump again at top speed, then how is that baseline useful? If I take a baseline reading at my typical speed, then what does an increase in pressure tell me? If I can run the system at a much higher pressure by setting the pump to top speed, then what is the meaning of a pressure that is higher than a low speed baseline, but still low pressure?
