Another way of putting it, is that TFP is all about using the right tool for the job. The TFP pool care method is based on accurate testing. When you know what you have in the water, you know what you need to add to keep it clean. People who use dry chlorine like powdered "shock" and tablets typically add them one time per week. The typical stabilized powdered shock raises the FC 10 ppm in 10,000 gallons of water, and raises the CYA by 6ppm. The FC will burn off but the CYA remains and builds up over time. For a 12 week swim season, 12 weeks of "shock" treatment adds 72 ppm of CYA to the pool. That is in addition to whatever the CYA level was at the beginning of pool season. The recommended range of CYA in a manually chlorinated pool is 30-50 ppm. It you keep say 3 tablets in a floater as well, they add an additional 3 ppm of CYA per tablet. If you use 3 tablets per week that is 9 ppm per week, and over 12 weeks that is 108 ppm of CYA. The week use of "shock" and tablets will leave you with 180 ppm of CYA, + whatever the starting CYA level was.
About the time you hit 100 ppm of CYA you will notice the water is getting cloudy, and typical pool store advice will tell you to add a second bag of "shock". That will clear it temporarily, but you have also increased the dose of CYA along with it. This is why we say liquid chlorine or bleach is the right tool for the job of chlorinating your pool. It doesn't add CYA to the water that you don't need. We recommend daily testing and dosing the pool only for what it needs.
Your friends who use "shock" and tablets may have pools that look ok at first, but they probably have at least one algae outbreak per season that requires additional pool store products to treat the pool. The pool store may tell them they have "chlorine lock" or "old water" (pool industry terms for high CYA) and that it must be drained and refilled to eliminate the problem. That is because the only way to get rid of excess CYA is to replace the water. In some climates where you drain below the skimmer and close for the winter and back wash a sand filter frequently during the season, you may replace enough water to keep the CYA levels down.
Sorry for the long winded answer, but this is why we use bleach.
