I just opened my pool...and have added salt in the last 24-36 hours.
This morning, took a test sample to my local pool store and reading was 3300ppm. My K-1766 test kit tells me it was 3400ppm. But just turned on my SWG and the reading says 2950ppm. Temp of water is currently at 70F (running the heater) so I think the reading should be fairly accurate on the IC-20.
So...it is either my IC-20 is reading wrong (or reading correctly). But my actual k-1766 test was reading 3400.
Suggested ideal for IC20 is 3600 by the way...which means I could be in range or out of range...depending on who I believe?
Who do I believe?
Who do I believe?
