White stain under water fall
chadly08
Active member
Mar 20, 2021
29
St. Louis, MO
CircuPool Universal40
My pool was opened today and I am reminded that it was closed down with an unsightly white stain under the waterfall:
Does anyone have a good procedure to clean this?
Thanks!
Here are some other ideas. Use at your own risk.
You may be able to use the purple scotch brite pads on the coping. Try it out in an inconspicuous area though to make sure it doesn’t scratch. If you have a cordless orbital sander you can place it on the pad and the scale comes right off.
