Hello all. New member here. At whit's end with trying to get my pool clear for the season. Opened to a green pool, balanced water and chlorinated the heck out of it. Now water is blue but very cloudy - cannot see the bottom or even the bottom step. Have tried PowerFloc at pool store's advice, nothing. Have tried DE in the skimmer - seems to do nothing but clog up the filter. Cannot vacuum the bottom because I cannot see the bottom or anywhere near it.
The common denominator here seems to be this white, slimy substance that collects in the cartridge filter (hayward). Simply cleaning with the hose does nothing to remove it. Spray cleaner does nothing. Have resorted to muriatic acid bath. Have a 30-gallon trash can filled halfway with water and about 3/4 gallon of acid. Have submerged each half of filter for about 15 minutes and still have some residue. Some of it comes out, I see it in the water however some is still in there. I don't want to destroy these filters but looking for advice on what that stuff might be and if this is the right solution to remove it.
I guess the net/net is that even if I get the white stuff out of the filter, it must still be in the pool. At this rate it will be Labor Day before I can see the bottom of my pool. Please help.
pH is about 7.0, Free Chlorine is 10, Total Alkalinity is about 80 and the Stabilizer is about 40. This is using the pool store test strips so cannot be sure of overall accuracy.
