- Apr 7, 2014
- 196
- Intex Krystal Clear
I started a slam today. I’ve been struggling with algae since my old SWG was not working correctly. I just replaced my swg and sand filter pump to the new one in my sig. I added the amount of chlorine in the pool math app this morning and turned on my pump. I accidentally turned on boost mode so SWG has been on all day also. Just shut down SWG and checked FC:
FC -15.5
CC - 0
Here are my other levels:
CYA -70
Ph- 7.2
TA - 70
I don't check calcium for AGP.
Will check again in am and continue slam if needed, but here is my question:
Its much less cloudy and just slight green tint. In the cloudy water when i look closely there are very tiny white “particles” in the pool. They appear to be throughout the whole water column. Hard to see but there. Is that normal in slam mode (been a LONG time since I've slammed) or something else going on? I did just replace my sand filter but it seems to small for sand. Cant get a good photo. Any ideas?
FC -15.5
CC - 0
CYA -70
Ph- 7.2
TA - 70
