Hi, I have some staining, but now I do not believe it is algae. where should I post this question and pictures? I already did a full Metal Erase treatment followed by stain and scale eliminator. Several stains around other areas of the pool came out, but these yellow/green stains remain. They do not brush out or move. Plaster is 3 years old diamond brite. Pool is crystal clear for weeks now. Water is balanced.
Apologies, as it is hard to photograph. It's basically only about 1 ft down from the waterline and a bit on the flat seating areas of pool and hot tub. It has lightened over the past weeks on the steps, but not much on the upper walls.
Chlorine on it doesn't do anything. SLAM process doesn't do anything, vitamin C pill rub does nothing, and the Metal Erase is basically several pounds of ascorbic acid which doesn't seem to help this further.
I have not tried muriatic acid down a pole as of yet.
I am the pool service guy for my abode, so noone else to really help me at this point. I'm kind of bummed because this pool is my oasis!!!
