When Does "Break-In end after Re-Plaster?
C4ST
14
S. Plainfield, NJ
I have read through the article entitled "Start-up New Plaster" and clearly see the instruction not to swim during the Break-In period. But it is not clear to me how long the break-in period lasts and what defines when the "break-in period" ends.
The start-up procedure given to me by my replasterer calls for me to hold pH between 7.2 to 7.6 from the start, and to hold the alkalinity at 80 ppm, with a calcium hardness of 150 to 200 ppm. I was told that I could add chlorine to achieve a free chlorine concentration of 1.5 to 3 ppm as of day 3. It is now day 9 after the replaster was completed, and I am having to periodically add moderate amounts of muriatic acid to keep my pH from walking up too high (I've been targeting to keep it at about 7.3 - 7.4). So at this point, pH, TA, and chlorine are at appropriate levels (7.2-7.5, 80 ppm, and 2-3 ppm respectively) and relatively stable--is it reasonable for people to swim in the pool?
Here is the start up card I like the best as someone who really knows plaster said it is spot on. Pair this with TFP levels and you will be good to go!Start-up Cards - National Plasterers CouncilPool School - Recommended LevelsGood job already having a good test kit!Now CANNON BALL into your pool!!!Kim:kim:
Kim, thanks for your feedback. I received this startup card from my plastering company and have been following it as carefully as possible. It states "It is recommended that you do not swim in the pool until the water is properly balanced." My pool water was properly balanced within 3-4 days after completion of plastering, although obviously I've been having to periodically add chemicals (primarily acid) to keep the water balanced. I get the sense from TFP's Break In procedure that they are recommending waiting longer than 3-4 days to begin swimming, but perhaps I'm mistaken.
