- May 3, 2014
- 58,387
- Fiberglass
- Pentair Intellichlor IC-40
Above ground pools are known to have poor circulation. That can be a factor.
However, have you seen his pool? Is it as clear as yours? Do you know if he manages his own water chemistry? The only way you can sustain using pucks long term is to exchange out quite a bit of water fairly often. They can stay right on the edge of an algae bloom by nuking it with chlorine every week. But the pool will never be as clear as a TFP pool.
