When and how to add chemicals
OscarB
56
Mantua/nj
I just SLAMed my pool for the first time. Now that my chlorine is to the level I want to maintain it, I wanted to bring my PH and TA level down. I added some muratic acid and left the pump running. When is it safe for me to add chlorine again? Could I have done it right away? An hour later?
Also, my kids jumped in earlier tonight (before I added the acid). When I tested my water, I had a very slight indication that I had a CC level. Is that normal after having swimmers in the pool?
Oscar B
FC 6
CC 0?
PH 8.0
TA 130
CH 110
CYA 50
mknauss
22,761
Laughlin, NV
Separate the addition of acid and chlorine by at least 15 minutes with the pump running.
Swimmers can create a touch of CC. Will burn off rapidly.
Reactions: OscarB
Richard320
22,069
San Dimas, CA (LA County)
We consider CC of .5 or less to be effectively the same as zero. Swimmers can create it just from sweat and so on. It doesn't mean anyone peed in the pool, though that will certainly create some CC. I've had periods where the CC is .5 for a week and then just as suddenly disappears. Don't worry about it.
OscarB
56
Mantua/nj
One more question for you two - is there an easy way to pour bleach from a 5 gal jug? I’ve made some measurements on a 5 gallon bucket for when I need a lot and cup measurements for when I need a little but anytime I pour, especially when the 5 gal jug is full, I end up spilling some. What do you two do?
Richard320
22,069
My bleach comes in refillable 1 gallon jugs.
OscarB
56
Mantua/nj
I’m sorry to keep asking questions but I’m just very curious.
My first question has to do with people like you. You obviously are very experienced with pools. If you really know what you are doing and using the ideology of this site, approximately how often would you Slam your pool? In other words, you guys seem very experienced, do you go through whole seasons without needing to do the slam process?
My other question is about getting ready for swimmers. My pool has never looked this clear but then again, I haven’t had very much traffic in it yet. If I know that I will be getting a lot of swimmers what do you recommend? Do I raise my chlorine level in preparation or just deal with it afterward?
Richard320
22,069
SLAM? Never.
For swimmers you do both. Raise FC a couple ppm before a big swim party and take it up again after they get out. It'll look terrible immediately after a big party but overnight with high FC will fix it right up.
Reactions: JaySav
mariane
675
Southeast Michigan
+1 to what Richard320 said. We have done this and it works well. The first time it happened I was shocked to see the cloudy water after a pool party when all the kids got out. Found out here it's quite normal to have that happen especially with kids. :snorkle:
OscarB
56
Mantua/nj
My pool is still crystal clear and the only outlier I seem to have is my TA. I have put in almost a gallon of acid in the pool over 4 or 5 days and although the PH has come down, the TA is barely moving. Is there something else I should be doing or is it this slow of a process?
Oscar B’s Pool o’ Fun!
Build Type: Vinyl
Volume: 18500 gallons
Latest Test Result Summary:
FC: 7.5 (2 hours ago)
CC: 0.0 (2 hours ago)
pH: 7.2 (2 hours ago)
TA: 120 (2 hours ago)
CH: 110 (4 days ago)
CYA: 50 (4 days ago)
TEMPERATURE: 80° (4 days ago)
CSI: -0.50 (2 hours ago)
brucehenson
79
Taylors/SC
I am by no means one of the experts, in fact still a rookie however I'll add my 2 cents worth here.
The instructions on the Muriatic Acid jug suggest that you submerge the bottom of the jug leaving only the neck and mouth above the waterline. This worked very well for me using 1 gal jugs, I would think that since the water is supporting the weight you could still measure even when using 5 gal bucket.
Reactions: OscarB
OscarB
56
Mantua/nj
I’m very new to all of this, a TA of 120 is nothing to worry about? Is there any possible detrimental effect to having it above 90?
Richard320
22,069
pH will rise faster at higher TA. That's it. No more prone to algae, no skin irritation, nothing. Think it through.... where'd that high TA water come from? The tap. People drink that same water without ill effect. And if it's low, how do they raise TA? Baking Soda. People brush their teeth with it. It's harmless.
OscarB
56
Mantua/nj
Hi guys,
My pool continues to be crystal clear. I am so thankful for your advice. I even get a kick out of telling people about this site when they complain about their pools being cloudy or green. I have a few questions that I hope you do not mind answering...
1) My cya level is now at a 50. That’s a long way from where it was last summer. When it drops too far, is it acceptable to use some tricolor pucks in my chlorinator again to bring the cya level back up?
2) pool math suggests my FC range be between 4 and 8. I seem to aim for a 7 and by the time I test 24 hours later it’s down to about a 5. Am I doing this right? Should I be putting in less? More?
3) I have my filter on a timer to run from 7 am to 7 pm. By the time I get home from work, test the water and add chlorine, it’s late and the filter is off. Is it ok to add when the filter is off and just mix it around with a pole or should the filter be running for a bit?
Here are my numbers in case you want them..
Thanks again!
Build Type: Vinyl
FC: 5.0 (an hour ago)
CC: 0.0 (an hour ago)
pH: 7.8 (3 days ago)
TA: 110 (3 days ago)
CH: 160 (3 days ago)
CYA: 50 (3 days ago)
TEMPERATURE: 80° (27 days ago)
CSI: 0.01 (an hour ago)
mknauss
22,761
Laughlin, NV
Your pump should be on for 30 minutes prior to testing and 30 minutes after adding chemicals. I suggest you change it to 9a-9p or something so it is running for at least 30 minutes after you add chemicals.
You can use trichlor tablets if CYA drops. Remember, if you plan a vacation this summer of more than a couple days, you will want to use trichlor while you are gone and thus plan for that CYA increase.
Your FC targets are great. Best to never get close to the minimum FC.
Reactions: OscarB
