- May 31, 2022
- 674
- Plaster
- Pentair Intellichlor IC-20
So this pool came with the house. As you can see from the photo of the steps, the surface finish is inconsistent -- top step is grey with streaky brown staining, next step is less so, bottom step even less. The closeup photo shows the bottom of the pool: irregularly light- and darker-blue, with small dark (almost black) spots, mostly near walls or other vertical surfaces. Brushing, even with a stainless-steel brush, doesn't affect any of this.
What has happened here, and what can I do to fix it -- especially the brown staining? Is the inconsistent/missing blue surface just due to wear? Is the staining from metal, or something else?
Some background info:
The pool had previously been maintained with trichlor tabs in a floater, cal hypo shock, and muriatic acid -- and I also found a half-empty can of Clorox XtraBlue dichlor shock, a bottle of Clorox Super Water Clarifier, and a bag of soda ash. When I moved in, water was clear but pH was low (6.6) and CYA was sky high at around 200. Water costs 5 cents/gallon here, but I gritted my teeth and exchanged enough to bring the CYA down to 50.
Now I'm maintaining the pool with liquid chlorine (in an automatic feeder) and muriatic acid only. Water is clear. My Taylor reagents are old so I'm waiting for a TF-100 kit to arrive later this week, but FWIW, the Taylor readings do match what I get from LaMotte test strips:
Any ideas?
- FC: 5 ppm
- CC: 0
- pH: 7.6
- TA: 100 ppm
- CH: 500 ppm
- CYA: 50 ppm
