- Jul 21, 2013
- 53,190
- Plaster
- Pentair Intellichlor IC-60
So here are the next steps in your plan:
- Add 3 pounds of dry stabilizer using the sock method.
- Keep your pump running 24/7 while the stabilizer is dissolving
- Once the stabilizer is dissolved from the sock give it another 24 hours to circulate
- Then do a Overnight Chlorine Loss Test to see if you pass or if you need to do the SLAM Process
- We want to get your pool algae free before you raise your CYA to 60-70 and turn on your ichlor SWG.
