Yep, test and adjust it up or down based on FC level and the [FC/CYA][/FC/CYA]. More here on dialing in your SWG, Pool School - Salt Water Chlorine Generators
After adding the 4 cups of CYA in the sock, it was no where near dissolved. I was able to mash the CYA around and get it out of the sock and brush it to nearly completely dissolved. How bad is touching a sock full of wet mashed CYA, being an acid and all? I really don't know too much about these chemicals and need to really find out what is corrosive/dangerous? So is CYA like chlorine tabs or not as bad? 2nd question, the chemical regents in the test kit? Should I avoid at all cost getting them on me, concrete, chairs, etc., can I pour the final tests down the drain, in the grass? What about rinsing the test tubes in the pool after testing, big no-no or ok?
Due to the unseasonably warm weather I decided to add salt and fire up the SWG. I was 30 days past the initial fill so I said what the heck. I overshot the salt but assuming the ~400+- differentiation reading (and the SWG is happy) it's reading "chlorinating at 70%". I was extremely surprised when I took the FC reading and it was 6.5, that is the highest FC reading I have taken. When I added the salt this weekend, I tried to raise TA and get my FC around 6. I added 4 cups bleach and 5.5 cups baking soda.
So my question: To try and dial in the SWG, should I take a reading tomorrow mainly focusing on FC to verify if I am over chlorinating? The SWG was set at 70% when it fired up, so I didn't know if that is a starting place or should I turn it down to 50%? I know that when spring comes around I am going to raise CYA higher, but I figured I would keep it lower now as the SWG may have a few weeks run time.
POOL TEST
Salt 3600
CYA 40
FC 6.5
Ph 7.8
TA 70
CC 0
CH Didn't test (last test 300)
We encourage sock squeezing to dissolve the CYA faster.
I would definitely encourage solar panels. They have given us many swim days that we would have otherwise missed due to the water being too cold from cold fronts or rain. We like our water 85+. 87 is even better. A solar controller helps a bunch to make it work better. A solar cover also helps a lot to hold in heat on cool nights.
You can do a little back of the envelope, or you can look up the actual output of the unit, and calculate that way. I'd say, you are in a safe FC place, so back of the envelope is Ok.
So lets say you are at 6, and tomorrow you are at 8. And before the SWG, you were using x per day, lets say 3 for the purposes of this.
So if you are at 6, you lost 3 and you are now at 8, you made 5 for the day, and wanted to make 3.
So...
0.70*5/3=0.42 or 42 percent. Put your real numbers in, but this will get you pretty close. Then just adjust every few days, and remember to add more when you get heavy use. I do this by adding a few hours of a "cleaner" cycle so I just run the SWG longer rather than ticking it up, and then having to remember to tick it back down.
That is pretty odd. Shouldn't be from the CYA, I've squeezed many lbs of CYA out of socks with no side effects. Maybe your hands need to be broken in to being in the pool all the time?![]()
Yes, I let solar do most of the work for free and then top it off with the heat pump as needed. We swam the last couple of weekends. I set solar to heat to 93 to get as much free heat as possible. Then on Wednesday I see where we are on temp. The last time we were at 85/86 with just solar and the cover. This was with air temps in the low 80s and night temps in the low 60s. I put the heat pump on a timer to run 10a to 6p and set it for 88 degrees. By Friday evening we were at 88 and life was good! This was our first fall with the heat pump, I just installed it a few weeks ago. Definitely a good add!
Normally, solar alone will keep my pool right at the avg daily high temp when temps are in the mid80s and up during the day and 70s at night. Or several degrees above the high temp with the cover. When temps drop into the mid-low 60s at night then I need to add the cover to keep the water at the avg daily high temp.
Our solar is a bit undersized for our pool and level of shade because I ran out of room. We have 240sf of solar and about 700sf of pool. Normally you want solar to be somewhere between half and 100% of your pool sf. Ask all the questions you want when the time comes. There are lots of pics in the link in my sig.
Yes, those things will push PH up. Did I write that, it looks familiar?![]()
