What to backfill with - semi-inground AGP
Nathan8372
56
South Texas
Intex Krystal Clear
Moved from here.
I'm bumping this post. What is everyone backfilling with? Dirt from the hole, sand, gravel? My manufacturer recommends concrete slurry but I'm not burying it all the way - only going 2' . I've heard bac things about using gravel and sand because it can shift during a liner change. The only thing left is native soil.
Mdragger88
1,923
Hernando, Ms
Intex Krystal Clear
Moved from here.
I just replied to your old post- we are mostly buried like u & just went with our dirt filling & stomping & then filling some more as it settled after every rain. We have had some shifting of our cove in one spot near a deck support but I believe it’s because we should have waited for more settling to take place before adding our deck. My father in law showed up w/ wood & just started building so I wasn’t about to turn him away
Reactions: Nathan8372
AJ.A
70
NE Ohio
CircuPool Edge-40
Mine is buried about 3 feet on one side. I ended up using gravel as I had relocated all the dirt to fill in a low spot in my yard. I just installed my pool last summer so not sure of the longevity of the solution. Only thing I wish I would've done is put some drain tile at the bottom to divert the water to the other side of the pool. Had a really heavy rain at the end of the season and could tell the water kind of sat there but doesn't look like it washed away any of my sand base.
I think you could get away with anything but might want to follow manufacturer recommendations to try to prolong the life of the pool.
When it comes time to do the liner I will probably roll the dice and drain it slowly and see what happens.. I am getting a deck installed there this summer so will be hard to shovel the gravel out. I also thought that gravel would be easier to shovel out as opposed to dirt to change the liner.
Mdragger88
1,923
Hernando, Ms
Intex Krystal Clear
Same - wish I would’ve added drainage. Praying my liner lasts a good long while.
Mdragger88
1,923
Hernando, Ms
Intex Krystal Clear
What kind of drainage woudl you use / how would you do it?
A perforated drain pipe in a ditch w/ gravel around the entire pool to down the hill. I likely will be doing this in the future- also my backfill wasn’t fully settled before my deck was put up so one of my deck supports has shifted. My father in law showed up w/ wood to build it so I couldn’t really turn him away. I am going to have to pull up some deck boards to repair that & will do the drainage then.
kellyfair
4,180
Tampa, FL
Intex Krystal Clear
Man - it's about 200ft to the end of my yard as it's graded from the pool. i'm not sure i'd want to trench that...
But... but... you are a gopher!
You can rent a trencher to make life a little easier!
  • Haha
Reactions: Teald024
