Re: What size pipe to plumb my pool and spa?
I checked out a couple of the videos on the link you provided. Thank you!
The centrifugal switch plate is cracked, so since the pump repairman I took it to said, "I've been working on pumps for 31 years and I've never seen one like this," I'm trying a JB Weld fix on it. It's a dual start switch on an old MaxFlo Dual Speed. The steel screw that holds the plate on the aluminum casing was fused and broke off so I drilled it out and will have to tap it. Good thing I'm retired and have time to putter
Question: If my overflow spa is 25' from the pump room and about the same level, do I need check valve(s) if I bring my diverter valves above spa water level? Is there still siphon action then? Is it better to do that or use a check valve? Thanks
