I was just wondering what type of plugs work best for the intake and return lines for winterizing your pool ? Last closing I used the threaded type with the O-ring. Seemed to work fine. Your thoughts ?
Personally, I shy away from them. I like the black rubber winter plugs. Mine leaked. If yours do not have leaks, then use what you are comfortable with. If you use the black plugs, wing nut at the 6 and 12 position.
