Hi everyone,
I'm working to transition to this program and stopped using chlorine tablets this past week. We've had tons of rain so I went ahead and did the complete test again and I will attach the results.
A few questions-
Since I'm not using chlorine tabs, do I now just check chlorine levels daily and add bleach as needed?
According to the app, the pH was in the normal range, but slightly above the target. Should I purchase and add dry acid to reduce yet? We're forecast for continued heavy rain, if that matters.
Should I get a water thermometer?
Should I ever add algaecide as a preventative?
A few questions-
