When the cell is turned off it is not degrading (at least not at any rate that matters in practice). There is no calcium carbonate buildup because there is no pH rise because there is no hydrogen gas generation. There is no coating dissolution or substrate passivation because their is no electrolysis when the cell is off and there is no chemical attack from the pool water. The wear on the plate material comes from the chemical and physical processes and by-products of electrolysis, not from some metal plates simply sitting in the pool water.
For example, oxygen that is generated as a by-product (when chlorine gas is the desired product) can migrate to the titanium substrate and thicken the titanium oxide (TiO
2) passivation layer thereby increasing resistance which increases heat generation and temperature and can ultimately lead to cell failure by lowering its output (at the same applied voltage). This is why some plate coatings have an intermediate coating layer to inhibit such oxygen migration to the titanium substrate. Likewise, oxidation of the ruthenium oxide coating from RuO
2 to RuO
4 destabilizes and removes the coating lowering chlorine output, increasing oxygen output, and resulting in further oxygen oxidation attack especially to the now exposed substrate. Surface deposits on the coating effectively increase the current density of the remaining coating that leads to more wear, but polarity reversal effectively removes such surface deposits. Reversing polarity too frequently, however, results in faster degradation since in effect the current density becomes concentrated with gas generation at the outer coating surface thus stressing it until conditions shift to allow for gas generation over a thicker volume of coating. Also, until the acidic conditions build up from chlorine generation, the oxidation of the ruthenium coating is more likely.
RuO
2 + 2H
2O ---> RuO
4 + 4H
+ + 4e
which is more likely under alkaline conditions during initial polarity reversal instead of
2Cl
- ---> Cl
2(g) + 2e
which is followed by
Cl
2 + H
2O ---> HOCl + H
+ + Cl
that creates acidic conditions
It would seem to me that the polarity reversal should be done by first shutting off the cell giving time for conditions to become more pH neutral and then to more slowly ramp up the current (i.e. current limit the power supply) to give time for conditions to equilibrate and chemicals to migrate to favor chlorine production over oxidation of the ruthenium oxide coating.
This is why I started the thread
Economics of Saltwater Chlorine Generators to show that the larger cells were much more economical because their prices did not increase linearly with their output and the lifetimes of the cells were similar.
