Also it’s color codedFrom 20 to 24
You just got some new liquid chlorine correct?Also it’s color codedone scoop powder in 5 mls add drops and count. Cannot fathom this! I’d lose my license if I made med mistakes like this! I’m accurate to a fault!
If you're using a Taylor vial marked 10ml, definitely put the stir bar in after measuring.bottom of the meniscus at 10 before the rod is put in
Fc this morning at 6 am is 20.Curious to see what numbers you get tomorrow. Good luck.
Added 635ml of 12.5 per instruction booklet that uses 12 percent so overshot a little but won’t test mid dayFc this morning at 6 am is 20.
Duh x 3 moreAdded 635ml of 12.5 per instruction booklet that uses 12 percent so overshot a little but won’t test mid day
Rats.Fc this morning at 6 am is 20.
Maybe by tonight - tomorrow I’ll have it tackled. I can’t fathom trying to tackle the stains- you have to bring fc to zero right? Lol no wayRats.So from 22 to 20. Well, pretty close and at least what appears to be good FC readings.
That's a project for when the water is cold like just before closing or early spring for sure when the water can handle a low FC level.I can’t fathom trying to tackle the stains- you have to bring fc to zero right?
My husband wants to fill it in with dirt lol. But I’m in CHARGE NOW… also maybe time for a new liner while we’re still working. This one is 10 yrs and served us well. Amd now that I’m an expert I can prevent staining in the future. (High ph and high FC right?) any other causes? AlgaecideThat's a project for when the water is cold like just before closing or early spring for sure when the water can handle a low FC level.
Correct. Also the amount of metals in the water (iron or copper). The higher the content the easier it is to react with the pH and FC. Copper (i.e algaecides and "Blue" products) are generally the worst because there's no way to remove it other than exchanging water. If it's iron (well or some city water), sometimes you can use a process with polyfill to help filter (capture) the iron to help eliminate the material and reduce the likelihood of it happening again.(High ph and high FC right?) any other causes?
Got the ladder out . I see 2-3 pin holes in my entry steps wondering if the sootI see is coming from there. Would soot use up chlorine? I didn’t see the installation/ do they typically put steps right over dirt or is there vinyl under? W decided our liner is 13 years old we are replacing it in spring so I’ll live with the yellow liner. Looks awful but my fault- added algecode and metal out while shocking thanks LeslieAbout the ladder, can you get in & take a peek under the treads that are in the water?
As for the stains, finding the source is imperative- it will help you determine if you can eventually become sequestrant free or not. The path can be different for everyone. For some its an ongoing process due to their fill water.
As Tex said, Algae first and stains later..
Will post laterGenerally the liner goes around the steps.
Pinholes aren’t good- there are ways to patch them.
Pics?
